Merc225hp
Yes I will be taking pix and will post them, then in the fall when I slow down for the season I will make a DIY.
Lot's have issues with the CAD system, me I have never had one problem with it. Lot's also go to the posi lock cable system, you might check that out. The posi-lock gets rid of the vac stuff and replaces it with a cable.
Edit: I need to see your upper ball-joint in a pix to say yes or no if you can do this. The diff must be 99 or under to do this swap. If you have the BOM number off the diff that would also help me out.
