Hello - 1st time poster.
I bought a 2000 Ram 1500 Extended 4x4 with 5.9L and high mileage (198K).
Everything functions properly except the transmission. Seems like in 1st and in 2nd gear it will rev high until I take foot off gas, then it will switch smoothly. All gears will shift beautifully/silently but going from 1 to 2 and then from 2 to 3 I can only do by letting foot off gas.
Per my research this is extremely common and is the governor pressure sensor + solenoid.
For $98 I ordered the set: A518 48RE 42 Transmission Governor Pressure Solenoid Sensor Transducer Kit 00 | eBay
And I am having my mechanic put it in (1.5 hours labor).
Question is what is the probability that this will correct the issue? Because it is so common I am hoping for a 50-50 chance. Can anyone put a percentage guess on whether it is a blown transmission or the common solenoid/sensor failure?
Fluid is red. No engine codes or any lights on dash.
