2001 46RE won't shift without coaxing
Discussion in 'Tech Info' started by vandor, Sep 13, 2017.
  1. vandor
    vandor Junior Member
    Sep 13, 2017
    DFW, Texas
    Ram Year:
    2001
    Engine:
    5.9
    Hi,
    Newbie here, I'm trying to help out an old lady by selling her late husband's 2001 Ram 1500 4x4 (107k miles). It has sat for ~18 months after he passed away. At first the truck would not shift form 2nd to 3rd unless it was put into Neutral for a few seconds, but after some driving usually it won't shift out of first either unless it's shifted to Neutral. Sometimes it will shift at high rpm, but usually not. Her brother replaced the governor pressure sensor and solenoid (and of course the fluid and filter), but it has not gotten any better. I read up on forums, but I did not find any obvious answers to what it could be.
    My plan is to replace the valve body and adjust the bands, and hope for the best. Am I on the right track?
    BTW, I removed the valve body last weekend, and the accumulator piston only had the larger spring, not the skinny one. I looked all around to see if it fell somewhere, but I can't find it, so I'm assuming there was not one there? Is that even possible?
    Any help would be appreciated!
    Thanks,
    Vandor
  2. dudeman2009
    dudeman2009 Senior Member
    22
    1,508
    177
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    You're looking at a rebuild at some point in the near future. The first thing to do would be to perform a fluid and filter change and also adjust/inspect the front band. It's likely worn quite a bit if you have to shift to neutral first, mine is doing the same thing, I have to floor it to near redline then let off the gas and shift to neutral then back into gear after the Engine rpm drops to below 2k.
  3. yoda
    yoda Senior Member
    48
    302
    117
    Jul 25, 2016
    Ram Year:
    Engine:
    If it is a 5.2 its only supposed to have 1 accumulator spring, the 5.9 has 2.
    Have you checked the throttle pressure adjustment, made sure its not stuck at wide open throttle, return spring is in place?
  4. SYKRAMMAN
    SYKRAMMAN Senior Member
    611
    83
    Jul 10, 2017
    Jersey shore
    Ram Year:
    02 qcsb slt 3.92's
    Engine:
    4.7 Puppy
    Throw a junkyard trany in it for 200$ then sell it. Instead of throwing parts at it and wasting your money. A trans swap is very easy to do on those. Good luck man, if you lived closer, I'd buy it from you.
  5. vandor
    Sep 13, 2017
    DFW, Texas
    Ram Year:
    2001
    Engine:
    5.9
    Hi,
    Thanks for the replies. It already had a fluid/filter change with no change in behavior. I'll adjust the bands this weekend.
    The engine is a 5.9, so it should have 2 springs. I will check if it's even available new, I'd hate to have to take one apart at a junkyard.
    It's a 4x4, so I'm guessing the tranny removal is not as easy as on a 2WD, or am I wrong? A junkyard tranny would also be an unknown quantity, but would be the cheapest option for sure.
    Thanks,
    Vandor
  6. dudeman2009
    22
    1,508
    177
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    Engine:
    Magnum 360
    New ones are near impossible to find for less than 3K, rebuilds are around 1.2-1.4k, used rebuilds 800+. I just bought one from a junkyard for $450 and thats keeping my old one, trans was rebuilt at 140kish and it had 193k when it drove in. I pulled it apart to check and its definitely better than mine. I just have to install the shift kit.
  7. Ford300runner
    Ford300runner Junior Member
    Sep 21, 2017
    Ram Year:
    1999
    Engine:
    360
    If you intend to keep the truck and replace the transmission anyhow, you might want to replace the pressure solenoid and the governor pressure sensor and see what that does for it. You can alway's pull the parts off and throw em on the shelf for the next dodge transmission thathe haunts you. I've seen it fix the shifting issues and I've personally replaced them when it didn't but for a $80 investment that could save you some major headaches
Share This Page
