2001 5.9 gas Aftermarket EFI
1974mcmopar
strum wi
I want to build a 408 for my 2001 2500 Ram. My concern in that is I want aftermarket EFI and, it to be plug and play, and work with my factory computer. I am good with a carburetor style as I have the intake already. I have been looking at the ****** 2 but don't know if that will work with the factory computer. I have been searching but nothing comes up with using the factory computer. Do I need it to make everything else work?
Thanks
1974mcmopar
strum wi
Well this will be harder than I thought. I must be the first person that wants to keep my factory computer and a aftermarket EFI. I will post back when I figure it out and hopefully help the next guy save time.
Thanks
Mike Holmen
airdrie, alberta Canada
magnum 5.2/5.9 hemi 5.7/6.1
cool build, but its going to be pricey build. You can do what your suggesting, but the check engine light will be on. You could also re-program the ecm and run the Hughes air gap. Keep the pics coming on the build
Racer9
Erie PA
Have you contacted a tuner? H o ll e y has several systems, it seems they should at least have some advice. I'm no computer whiz, but it sounds like all you're doing is changing the oem throttle body to a different injection system, it shouldn't be that hard.
