2003 4.7 shutting off while driving
slamdram
North carolina
Ok so I have a 2003 with a 4.7 and I'm having a issue with once the truck gets up to operating temp it will shut off with no warning. No check engine lights or codes. Will start right back up and some times can drive for a few miles or only a couple feet. Have replaced cam sensor,ignition switch and cleaned grounds and check fuse box for any kind of corrosion on terminals and so far nothing has fixed it.
S
slamdram
North carolina
Is it possible to be a coolant temp sensor related because truck drives absolutely fine till it gets to operating temperature. Then once it does that is when the problem starts.
S
slamdram
North carolina
Is it possible for anyone to get a ohm reading on a good operating coolant temp sensor for a 2003 4.7? So I can compare it to mine.
fastf
Georgia
2005 Ram 1500 Quad Cab SLT Thunder road
Get yourself a repair manual if you don't have one it will save you a lot of money.
