2009 1500 key fob reprogramming trouble
The Mace
Hey all... I'm trying to program a new key fob for my '09 Ram 1500 SLT, but having no luck. I have two working fobs. I've been following the process in the owner's manual, which mirrors almost every process I can find online...turn one working fob to "on" for more than 3 seconds (less than 15), turn off & remove...turn second working fob to "on" and wait for chime & blinking security light...insert new fob, turn to "on", etc.
The problem is, I never get the chime and blinking security light with the 2nd working fob, no matter which one I use or how long I wait (it's supposed to take 10 seconds). The truck doesn't ever seem to go into "programming mode," so I never get the chance to put the new, unprogrammed fob into the ignition to program it.
Am I missing a step? Any thoughts? Thanks in advance.
The Mace
The Mace
Sorry to say I don't have Alfaobd. Is there another solution?
mrack
Not that I’ve found, very little info out there for 09-12 and what little there is doesn’t seem to work anyways. See how much it would cost to have a locksmith do it, or if you like DIY getting Alfaobd will likely be a comparable price and you can use it for other things in the future.
