2010 4x4 lowered?
bnokle
2007 3500 ram
I have my dads diesel here and am thinking about buying it. But I have to use a chair to get around so if I was to buy it I need to come up with away to lower it first. 4" in the front puts it right around the same height as my 99 2wd. I know I will be making it ride worse but what else is there? I could run a shorter sidewall maybe for that last 1/2" but the solid axle really limits it.
jws123
nj
Well you could always remove the front driveshaft pull the cv axles and make it 2wd might make it easier to lower since axles wont be there but not sure I never lower things.
B
bnokle
2007 3500 ram
I forgot to put in its a 2500. A 1500 would be easy.
jws123
nj
Yikes not sure what your going to be able to do there never personally seen a lowered 2500 maybe look at some options of something that lifts you into the truck i know some exsist. Or just find another truck that can suit your needs.
FinestTitan70
