65GMK
2010 Ram 1500 4x4 5.7 quad cab. Fixing to have to do the cam and lifter replacement. Thinking of going mds delete but wanting to stay with stock mopar type cam non mds but I think my year is VVT. Part number that's works for my application along with the correct non mds lifters would be nice. The push rods I currently have in my truck should work? Also looking at a tuner that permanently shuts off the mds and ups the speed cut off a bit. 25 miles evey day on a two lane road. Pass when and much as you can type thing. Also looking for a tuner that will do the speed limiter and mds off and remain so with the ability to remove the tuner from the vehicle. I have no desire to have a permanent electronic device hooked up to my truck. Just something else to give problems. Will a super chips tuner meet my goals and if so which one would i need. Thanks. Also looking for the oil pump part number. Figured its probably trash after all the metal from cam and lifter has been ran through it.
