2011 3500 6.7 what does key in fob do?
Avas truck
Alberts
Hello first time posting just bought a 2011 3500 6.7 and my buddy was saying can start the truck with the key don’t have to stick the fob in, anyone know how to do this? Thank you
Administrator
I think your buddy is mistaken. The fob has an RFID chip in the tip, that's how the truck knows what fob is allowed to start the vehicle, not sure how you can get around that.
You don't even need a battery in the fob for the RFID chip to work. The physical key is to unlock the door and tailgate if the battery dies.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
This is just for information
The Heavy Duty Rams are 1 year behind the 1500 models
so a 2011 Ram Heavy Duty is the same as a 2010 Ram 1500, function & parts wise
As far as FOBs go, there are 2 basic shapes beginning with 2013
The Fob for your Ram will have a shape similar to this, unless someone modified it.
Sorry for the oversize images
The one with the x2 on it, will start up when you are maybe 30 feet away from your Ram, just press the x2 button twice & it should start
( some Rams windows will open, if you press the X2 button twice & continue to hold the x2 button down )
the type below will only lock & unlock the Ram from outside
The PANIC part of the FOB must be inserted into the ignition to anything else, like to move it
GTyankee
3.0 ecodiesel
Beginning in 2013, the RAM 1500 began using this type
You never stick it into the ignition, you can just leave it in your pocket & push the ignition with your finger
caulk04
This key was an option, not all have it.
But the key you find inside your FOB is just to unlock the door in case the battery is dead in the truck or FOB.
A
Avas truck
Alberts
I got a few keys cut today these are the keys
GTyankee
3.0 ecodiesel
That type of key, is called a Transponder Key
The inner part of the Transponder Key has a Circuit Board in the grip part,
it can be programmed just like a FOB & they are less costly then the other kind of FOB.
Transponder Keys are often used by people who go hiking or swimming,
Thin & compact
Chipped, or Transponder, keys are keys that have an RFID (Radio Frequency Identification) chip inside the head of the key. These types of keys have become an industry standard for vehicle manufacturers. This is because the RFID chip adds an extra layer of security to your vehicle's ignition
Full explanation of Transponder Keys
