2012 1500 Cranks but won't consistently turn over and is getting worse (seems to start better on hotter days)
ocifferdave
USA
A month ago my truck started having issues with remote start. It might turn on, or it might try, sounds like it started, then turn off after 2 seconds of the engine struggling. Turning it on manually via key turn would work with a little bit of struggle (you could hear the engine attempting to turn over, but almost stall out but then run fine).
I had noticed on hotter days it would start up with less struggle.
Lately, its been hit or miss if I can even turn it on via key turn (I don't try the remote start anymore since that keeps failing now).
No engine codes.
No work done on the truck since I got it two years ago (besides the standard oil changes).
Thinking this might be a dirty fuel line issue, I put in the highest grade gas into a near-empty gas tank a week ago along with a fuel line cleaner additive -- no difference, still getting harder to start.
Last two days I cannot start the truck.
Here's a short video of me trying to start the truck today:
https://youtu.be/Z1IKamNSjdU
It's hard to hear, but you can hear the engine starting to turn on then fail. After the second attempt you hear for a split second the engine trying to turn over, but then afterwards its only the sound of the ignition cranking. I even trying pumping the gas peddle (something I have not tried to do before the video today), but that didn't seem to make a difference.
Ideas of what I can try next?
P.S. Letting it roll down a hill in neutral while the engine is off with the key turned to the on position and then throwing it into drive doesn't do a thing.
10/2 UPDATE: Because of this forum I was able to fix my own truck for only $46 and avoid a potential $1300 auto shop bill. Thank you very much!
The Fix: https://www.verticalvisions.com/tipm-test-bypass-cable-mini-blade-fuses.html
XCELLR8
Central Illinois
Fuel pump relay
WIN Unit
Are two places to start. You need to find out if it is getting fuel or spark, that will tell you where to go.
csuder99
Sounds like no fuel, check fuel pressure at the rail. It might be the fuel pump relay but not very likely. You can just swap the relay with another non-essential one (e.g. horn) and see if it makes a difference. More likely the fuel pump.
SYKRAMMAN
Banned
Jersey shore
06 Mega
P.S. Letting it roll down a hill in neutral while the engine is off with the key turned to the on position and then throwing it into drive doesn't do a thing..
That trick only works with manual trany's. Auto trans work off of high pressure.
CamperMike
Peoria, IL
Csuder, Fuel pump relay is in the TIPM and is troublesome on Mopar vehicles from that time. I don't think it happens as often with these trucks as other models but it still happens. I would bypass the relay and see if it starts better.
csuder99
CamperMike, you're right. The run/start relay is conventional but the fuel pump relay is integrated. Doh !
OP: To check if the fuel pump gets power check if there is 12V at fuse 70 in the PDC during cranking.
O
ocifferdave
USA
This was the issue, @CamperMike. Thank for saving me a lot of money and headache by pointing me to what turned out to be the issue.
O
ocifferdave
USA
Yep, CamperMike is my hero -- that was the issue and it only cost me $46 to fix it:
OasisNinjaBat
