2012 In Cabin Air Filter Modification
BlownGP
Houston/Baton Rouge
Got the filter, haven't had time to pick up the cover yet.
ramstein
So I did this mod but have realized a slight problem. I couldn't cut out a perfect square with the knife I had, so I had to do some trimming. Evidently a few small pieces of plastic made their way into the blower fan and now I have a pretty obnoxious rattle when I turn the fan speed up over the first setting. Any bright ideas for getting the pieces out? My hand can't fit down into the fan so that idea is out. Is there an easy way to access it from underneath???
UNBROKEN
2012 Ram R/T
I'm not sure because honestly I've never looked but if it's like the 3rd Gen's you can drop the whole blower motor straight out the bottom with 3 screws and one plug to undo.
It's worth a look under there.
Dale.0
hemi
Where can I order both these parts online?
Dale.0
hemi
When I type in the part numbers at Allmoparparts.com they don't recognize those numbers. I typed in 05058693AA and 68052292AA
Dale.0
hemi
I found the cover, but cant find the filter
Dale.0
hemi
That's what im looking for. Chewy your the man. Thank you.
phillips66
Illinois
Just did the cabin air filter mod and noticed that the courtesy light for the passenger feet has no wires going to it, any one else notice this or is the wire hiding somewhere??
Dome light under glove box
Inside in front of heater fan below air cabin filter
Sent from my iPhone
phillips66
Illinois
Never mind, I found the wire, it was tucked up by the kick plate, must have gotten missed in assembly!!!!!
Sent from my iPhone
Texasez
Dallas tx
Can someone tell me which part number they used that worked well. The one I used seemed too long and bunched up. Thanks
phillips66
Illinois
It should stick out about 1/4" and then the door covers it. Did you rotating 90 degrees?
Sent from my iPhone
Texasez
Dallas tx
Ya. It wasn't any better. Mine smashed in with the door on and folded in on the sides. I think when they did the part number conversion I ended up with a wrong part number.
phillips66
Illinois
Here are the part numbers I have come up with, the top 4 I got from other posts the other ones are from a conversion chart
CABIN AIR FILTER
Filter #5058693AA Mopar
Filter #C25869 Purolator
Filter #Haaf1328 Hastings
Filter #24578 Wix
Filter #3692 MicroGuard
Filter #CF10729 Fram
Filter #fil4578 Napa
Sent from my iPhone
Texasez
Dallas tx
Thanks. Ill try again. I gave them one of the part numbers last time they did their conversion and I ended up with one that seems too big. Ill see if I can order one instead of letting them find a similar part.
