2012 Ram 3500
bluejaka
6.7 L
Looking at a 2012 Ram 3500 Laramie Limited 4X4 to use to pull a goose neck horse trailer. Trailer weight is 7,000 lbs plus 2 horses for 2,400 lbs. Gear and tack 400 lbs. Its a living quarter trailer so not sure what to add for water....make the total approx 10,000 lbs. Assuming a hitch weight of 20% that means our payload is 2,000 lbs hitch weight, 600 lbs for 4 people plus gear and misc....apprrox 2,800 lbs.
I was really disappointed to find the GVWR is only 10,100 lbs for this model leaving a payload of 2,560 lbs for a 1 ton truck! This unit can't legally pull a 10,000 lb trailer.
Please tell me I'm looking at this wrong.
Here is a link to the stats.
http://www.ramtrucks.com/en/towing_guide/pdf/RAM.2500.3500.Towing.Specs.pdf
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Okay I am a complete nublet when it comes to figuring this stuff out.
Just a few questions... Is this 3500 a SRW or DRW?
I assume a longbed 4x4.
What rear axle ratio? 4.10? 3.73?
Go here: Ram Trucks - Towing Capacity Chart
Then hit "Look up my vehicle" you will need your VIN.
When I did that it pulled up my trucks payload and max trailer. Maybe that'll give you a definite answer. If I am reading it right it also gave me the GCVW.
B
bluejaka
6.7 L
The truck is a short bed 4X4 SRW with 3.73 gears.
I went to the link you provided and it shows a max payload of 2,693 lbs. well below what I thought it would be for a 1 ton. Max towing shows 13,450 and the GCWR is 21,000 lbs.
Big jump up in payload from 2012 to 2013 models..... A 2013 model shows payload capacity at 3,950 compared to the 2012 model at 2,693
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
They have made the new ones insanely capable.
jlb
MT
CTD
Get air bags, and I doubt anyone would even look sideways at you. Also, is 20% high? I tow goosenecks exclusively, but have never bothered to weigh axles when hooked up.
audio1der
Airdrie, Alberta
Oh, they can legally tow a 10,000lb trailer, but with only a driver, and no gear. That's YOUR problem, not Dodge's.
They're fiends, aren't they?:flipthebird:
