2013 Dodge Ram Quad Big Horn with hemi front sway bar info needed.
dss56
Boston
I have a2013 Ram Big Horn Quad with Hemi.
I notice my front sway bar on drive side has a crack like the steel when the end was flattened is de-laminating see picture.
So I would like to get another sway bar and replace it.
Would anyone have a good
OEm part # for the sway bar
and new bushings #
and the 2 outer sway links # or just new bushings.
jws123
nj
Mine did this not sure why it happened its honestly not that common I was to cheap got the welder out put it back together been fine ever since.
Socalramfan
Huntington Beach
2011 Big Horn
Holly crap o_Oo_Oo_O
Your best is to check a salvage yard, or better yet…… just go with a Hellwig Sway bar. I have Hellwigs‘ on and definitely a plus :waytogo:
Ive got the Oem one laying around, but seriously shipping cost from So. Calf to Boston doesn’t make that practical.
Also….. keep in mind that you’ve got some serious rust under there. Whichever route you go, will put more stress on those other weaken components.
Unless things have changed recently,nobody makes an aftermarket front swaybar for the 4X4's.
dss56
dss56
Boston
I will try the dealer Monday but looking on line used are $200-$300 so what would a dealer want. I will also try local salvage yards here in Boston area to see if I can get used and a better price.
The rust is all surface rust and that I will take care of when I replace the bar.
thanks for the replies.
dss56
dss56
Boston
Anyone have a OEM part # for the sway bar?
thanks
Hemi395
Cape Cod MA
thanks
So I just looked on allmoparparts.com and theres 4 different PNs for the front sway bar. Definitely wasn't expecting that.......
jawzs2
South Jersey
If you ever make it down to Florida a member here has one listed in the for sale section
dss56
dss56
Boston
Im sure its gone post is 1/9/22 almost 9 months ago
NJMOPAR
Older and faster
ELizabeth, NJ
You have to measure the outside diameter of your bar to get the right one (& matching bushings).
Usually anywhere between 28mm & 36mm.
dss56
dss56
Boston
Same here I cant tell what part # to use
Hemi395
Cape Cod MA
I'm assuming its probably the difference between the base model V6, Sport, Outdoorsman, etc. Probably would need to have someone run your VIN in order get the exact PN...
EDIT So even the "Fitment" section at the bottom shows the same trucks for all the sway bars....
dss56
dss56
Boston
Ill call a local dealer Monday morning with my vin they usually want the last 6# of the vin and some local yards and also LKQ I have local to me for a used one.
dss56
dss56
Boston
So I think I found the part# OEM
5154681AA thay are $118.00 for the dealer. So I will call tomorrow and see if in stock. I think the price on ebay have the shipping included even though they say free shipping.​
The # says its for all 1500 and also all motors 3.6 4.6 and the 5.7.
I will post tomorrow if any luck
pacofortacos
It looks tiny compared to my stock Outdoorsman piece.
dss56
dss56
Boston
2016 Ram 1500Going to call the dealer in morning to make sure its the correct part# here is a partial list of rams it will fit
Big Horn, Express, Laramie, Laramie Longhorn, Limited, Lone Star, Outdoorsman, Rebel, SLT, Sport, Tradesman
3.0L V6 - Diesel, 3.6L V6 - Flex, 5.7L V8 - Gas
2015 Ram 1500Big Horn, Express, Laramie, Laramie Limited, Laramie Longhorn, Limited, Lone Star, Outdoorsman, Rebel, SLT, Sport, Tradesman3.0L V6 - Diesel, 3.6L V6 - Flex, 5.7L V8 - Gas
2014 Ram 1500Big Horn, Express, Laramie, Laramie Limited, Laramie Longhorn, Lone Star, Outdoorsman, SLT, Sport, Tradesman3.0L V6 - Diesel, 3.6L V6 - Flex, 5.7L V8 - Gas
2013 Ram 1500Big Horn, Express, Laramie, Laramie Longhorn, Outdoorsman, SLT, Sport, Tradesman3.6L V6 - Flex, 4.7L V8 - Flex, 5.7L V8 - Gas
pacofortacos
Measuring is the most accurate way of find out for sure - vin might tell you though.
Orca
