2013 Ram 1500 Check Engine Light - Coolant Sensor
Mike_P
New Jersey
3.6L Six Cylinder
Check engine light on apparently due to engine coolant sensor per Autozone. Replaced sensor and 2 days later check engine light on again. Same error code. Anyone have an idea what may be the issue?
Robert Mc
Fresno, CA
6.7L Cummins
It is likely the float inside the coolant bottle that has gone bad. I know on the 2500's it is a common problem. You have to change the coolant bottle for a new one. This video will show you how to check the sensor: https://youtu.be/gB0-2aMFcZ0?si=02LREd_sGyeaDW4n But more than likely you'll need tot replace the coolant bottle.
Daw14
Always use OEM sensors , unless you enjoy rerepairing issues.
