I hope to buy a 2013 Ram 3500 4wd dually mega cab short box diesel for towing a to-be-purchased 2014 Excel 31IKE 5th wheel (17,5000 GVWR). Am buying 4WD to enhance resale value and “just in case”. But I’m worried about achieving a level towing setup. The Ram has a bed rail height of around 59” unloaded .
The newer Excels already come with the springs over the axle. The Demco pin box has a height range of 41.5-45.5”. Have any of you successfully leveled your newer fivers/ 4WD trucks and attained the minimum 6” bedrail clearance?
I asked Excel the distance between pavement and the fiver's overhang (when level) that sits over the truck bed was told 60". As a newbie (and terrible at spatial relations!), I'm confused. With a 59" bed rail height and 60" from pavement to Excel's overhang, that sounds like just 1" of clearance, far from the minimum 6" needed.
Adjusting the spring shackles from the default middle to bottom hole would help a bit. Also, does the type of hitch (5th wheel or gooseneck) and the brand make a difference re clearance? Will I need to actually lower the trucks suspension or will that cause other problems?
What is the difference in bed rail height between the 2013 RAM 3500 4WD and 2WD?
Sorry to be so ignorant, but I don't want to end up with a truck that can't tow my Excel !
Thank you in advance for your replies!
David L.
Dover, NH
David L.
Dover, NH
