2014 Laramie bezel & 2006 Recon headlights
Status
Not open for further replies.
matt.davidson09
2013 RAM 2500 Laramie Mega Cab
6.7L Cummins
Cleaning out the garage! A majority of these came off a 2006 Dodge Ram 1500 2WD 3.7L V6 Regular Cab Short Bed; might have other applications. All pricing does not include buyer-paid shipping.
2) These are 2 sets of Recon Smoked CCFL Halo Projector Headlights (Part number 264199BKCC). One set has very VERY mild "peeling" on the headlights - apparently this is common with Recons? Trying to capture it in the pictures, hard to notice unless you know it's there, and I'm sure a headlight restore/clear coat will fix the problem.
The second set is the exact same recon unit as the first pair - only these are scrappers that can be used to salvage parts from. All of the mounting brackets on this second set are broken and the LED bulbs and wiring has been removed from the unit (I have all of it - see pictures). I'm actually still on the fence about whether I want to keep these for projects or not lol good news about this second set is that the lense housing is flawless - at a minimum the lenses could be swapped with the first pair
Pricing is $450 for the first pair and $150 for the second. If you're feeling crafty I can do both pairs (all 4 headlights, plus wiring and bulbs) for $550.
4) OEM trim pieces - bezel under cup holder has 2 holes drilled in it. $5 ea
5) Lug Nuts (partial set) – only have 10 of these; will provide key. Size appears to be 9/16 – 18. $15
6) Detailing Stuff – pads/pad covers – don’t trust myself to not mess up my clear coat with these things. $15 for everything pictured
7) Gen 3 OEM Chrome Emblems – self-explanatory - $10
9) OEM Suspension – spindles, shocks, ubolts, etc...$130XXX miles - $75
daveray9
Did you have the Pioneer Headunit installed? You said you don't know how to wire it up, but with the harness shouldn't it be plug and play?
New Pricing:
Pioneer Headunit - $350
Laramie Bezel - $175
Recon Headlights - $450 for the first second; $150 for other set; both for $550.
Sent from my iPhone using Tapatalk[/QUOTE]
matt.davidson09
matt.davidson09
6.7L Cummins
Will the Laramie bezel fit with a 5.0 radio?
I don't believe so. It fit my 8.4AN but I have the center floor console and this doesn't work with my truck.
matt.davidson09
matt.davidson09
6.7L Cummins
Laramie bezel, body lift kit, Pioneer Headunit, misc parts galore
Yes it should be plug and play. I just meant that I had it done professionally so I wouldn't be able to help with the install or questions about the wiring.
daveray9
Got it. PMed ya. If I can find the harness for the 2012 and the NAV antenna I will take it.
ekholmgren
Boston Area
Based on that video, it may work. It looks like I'd have to reuse the inner trim piece from the bezel from my truck. Which also means I wouldn't be able to sell it complete. Let me look into this a little more.
ekholmgren
Boston Area
Also, that video is excellent. If it's not already in the 8.4 upgrade threads on the forum, you should share it over there. It's a great tutorial.
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
damn talk about an old bump, got any of the headlights laying around? if we can make a deal i could have some fun trying a few things with a set
matt.davidson09
matt.davidson09
6.7L Cummins
Yeah man I spaced on this thread and only remembered it because I just moved houses and had to move all this stuff from the attic! I have both sets of Recons available still.
Demon-HeMi
Houston
shoot me a price for the set that is in the worst condition lol
Status
OasisNinjaBat
