2014 Ram 1500 fuel pump problem
ArcticPowerWagon
Alaska
my pump went out twice in the same month!!!!
each time the 20 amp fuse was blown
the first time it happened no warning what so ever fuse was blown and pump was getting power but not turning (i had the bed off testing it before i ordered a pump)
so i ordered a pump which cost an arm thinking maybe it was its time to go out (44,*** miles) without trying to see why the pump went out
new pump came in a few days later and got it replaced drove around town with my odb tool watching the LD everything looked good
two days after installing the brand new mopar pump i go out to start the truck and it would turn over but not start so i checked the fuse and its blown again!
got it swapped and turned the key to on without starting it and no sound came from the pump again!!!
anyone please help I'm already 600 bucks broke and a half day of labor behind on my truck with no ride to work on monday.......
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Why is anyone paying for a fuel pump replacement? Shouldn't this be covered under the 5yr warranty? Since my 14 CC is leased I can tell u if this happens to be I won't be paying for it. Fuel pumps going out with less than 50k is crazy. I would drop the tank myself and swap the pump. As long as the tank is empty it shouldn't be too hard even just leaving it on the ground. I only got 12k on my 14 and how I drive I won't hit 50k for another 6yrs or more.
Brody57
Brody57
Oklahoma
2014 RCSB
That's exactly what I said when I had my problem. It's covered under the 3 year/36,000 mile warranty. It's not part of the powertrain according to RAM/Chrysler
blackbetty14
CT
That's a load of crap. Manufactures are really trying to stick it to the people. 3yrs lol.... cuz that's almost nothing.
surfjaves
same thing just happened to me. ordered gem mopar pump for 200$ the tanks looks pretty simple to drop. hopefully. has anyone dropped the tank have any tips.
hiram23clarke
Same thing happened to me today, luckily I drove it to the dealership before opening. An check this out 18,814 miles. I bought the truck brand new on 07/25/16
Sent from my SM-G935T using Tapatalk
stimpy433
IOWA
My 2014 had less then 10,000 miles on it when the fuel pump just died!!!!
Feli
I got a question, my truck wont fill up with gas and its empty, could it be my pump that is bad?
yoda
Fuel pumps have been 3/36 warranty for a long time. Nobody is trying to stick it to anybody.
The reality is vehicles have come a long way in the last 25 years, but the better they make them the more people expect.
Should a fuel pump last more than 3/36? sure. But anything that can fail, will fail.
I just had a customer complaining to me when a lifter failed on his Hemi with "only" 150K miles.
Not to many years ago 150K miles was normal rebuild time, or more likely new car time.
Rherman1
Sunny Florida
6.7 Cummings
I got the fuel level sensor today at the dealership. I was told it is a separate part and it sure is. I have gotten 3 CEL and the gauge goes to empty and the miles left says low fuel. It will come back and the CEL goes out, works for about 1/2 hr then goes back to being broken again. I plan on changing it out either tomorrow or Sunday am. I ran the tank down to what should only be 2-3 gallons left in it. The part was $137.00 but they wanted $462 to drop the tank and change it. Sorry that ain't happening!
Murphy Slaw
Southern Illinois
2016 Bighorn 4X4 Crew
Mostly 2014's, with a 2016 in here?
Why do I find these threads 2 weeks AFTER I buy a new truck......... ?
hiram23clarke
I also just had my 32gal gas tank replaced under warranty. At 21,278 miles
dengland
2014 Limited
I paid $132 for my dealer to tell me the fuel senor failure on my 2014 Ram 1500 requires fuel pump replacement. They want $700 to replace it. Argh. I was expecting about 1/2 that.
anotherjoe
My 2014 with 26k has the code....im not sure why i did not buy another chevy
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
my 2014 had the fuel sensor failure under 25k, ill look it up and see exactly how many mines i had on it but i know it wasnt much
Demon-HeMi
Houston
I took this pic after a month of dealing with the dealer and them saying it just needed a flash....
No reason for a 2014 to need a fuel pump, and my truck never goes below half a tank
stimpy433
IOWA
Fuel pump on my 2014 crapped out at less then 10,000 miles!!!
Demon-HeMi
Houston
im glad i wasnt the only one, i was pissed for sure, im much happier with my 13 i bought a few months ago over the 2014 i bought bran new lol
dengland
2014 Limited
I ended up paying the dealer. Mileage was just under 50K.
anotherjoe
Does anyone know what all the failures where attributes to? Dealer just replaced my pump on the last day of my warranty @26k is this something I can expect every couple of years or was the issue resolved
