2014 Ram 2500 5.7 Hemi- No Bus message, dash and wipers go nuts.
Non forsit
West Coast, USA
An update. I now carry an OBD scantool with me and check it every other day, so far no codes are stored that I can see with my tool, and the problem has not happened again. Even took it offroading this weekend without incident.
I posted this in another forum:
"Several members suggested Alldata, so I got a subscription, and pulled more information on the codes. AD also shows the wiring diagrams, in case anyone needs them. I am having to learn this as I go, but it looks like the Controller Area Network (CAN) went down. I kinda, sorta, think all these things have the Totally Integrated Power Module (TIPM) in common. Is that it? I dunno, but from suggestions here, I made sure all fuses and relays are seated.
Maybe this information can help others. I'll keep reading, and then read some more. So far the truck drives fine after having connectors and wiring checked and making sure all items are seated and without corrosion in the TIPM.
Just checked the topside of the TIPM, and all the fuses and relays, and a couple of the relays and the larger fuses might have been elevated by a millimeter or so, so pushed them back down straight. The post connections on the side of TIPM were all very tight, but took them apart and checked for corrosion, but they were all shiny and got tightened down again. Checked the main ground and it was shiny and tight."
U0001Air Suspension Control Module (ASCM) - Can C Bus
Full Time Drivetrain Control Module (DCTM) - Can C Bus
Hybrid Control Processor Module (HCP) - Can C Bus
Instrument Cluster - Can C Bus
Integrated Trailer Brake Module (ITBM) - Can C Bus
Occupant Classification Module (OCM) - High Speed CAN Communication Bus
Occupant Restraint Controller (ORC) - High Speed CAN Communication Bus
Part Time Drivetrain Control Module (DCTM) - Can C Bus
Powertrain Control Module (PCM) - Can C Bus
Radio Frequency Module (RF Hub) - Can C Bus
Security Gateway Module (SGW) - Can C Bus
Steering Column Control Module (SCCM) - Can C Bus
Transmission Control Module (TCM) (8HP50/850RE) - Can C Bus
Transmission Control Module (TCM) (8HP75) - Can C Bus
U0101Powertrain Control Module (PCM) - Lost Communication w/ TCM
U0121Active Vibration Cancellation Module (AVC) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Adaptive Front Lighting System Module - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Air Suspension Control Module (ASCM) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Body Control Module (BSM) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Drivers Assistance System Module - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Electric Power Steering Module (EPS) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Full Time Drivetrain Control Module (DCTM) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Hybrid Control Processor Module (HCP) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Instrument Cluster - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Integrated Trailer Brake Module (ITBM) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Occupant Restraint Controller (ORC) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Park Assist Module (PTS/PAM) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Part Time Drivetrain Control Module (DCTM) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Powertrain Control Module (PCM) - Lost Communication w/ Anti - Lock Brake System - ABS Control Module
Radio - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Radio Frequency Module (RF Hub) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Transmission Control Module (TCM) (8HP50/850RE) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
Transmission Control Module (TCM) (8HP75) - Lost Communication w/ Anti - Lock Brake System (ABS) Control Module
U0155Powertrain Control Module (PCM) - Lost Communication w/ Cluster/CCN
U02Active Noise Cancellation (ANC) - Lost Communication w/ Passenger Door Module
Amplifier (AMP) - Lost Communication w/ Passenger Door Module
Body Control Module (BSM) - Lost Communication w/ Passenger Door Module
Driver Door Module (DDM) (DMFL/R) - Lost Communication w/ Passenger Door Module
Radio - Lost Communication w/ Passenger Door Module
U0212Powertrain Control Module (PCM) - Lost Communication w/ SCM
U0402Powertrain Control Module (PCM) - Implausible Data Received from TCM
U0402-00
U0415Powertrain Control Module (PCM) - Implausible Data Received from ABS
U0416U0416-IMPLAUSIBLE DATA RECEIVED FROM ESP
NOTE: Treat this DTC as an IMPLAUSIBLE SIGNAL DTC when performing the COMMUNICATION DIAGNOSTIC PROCEDURE.
The COMMUNICATION DIAGNOSTIC PROCEDURE MUST be performed before replacing any component(s) or module(s). Perform the COMMUNICATION DIAGNOSTIC PROCEDURE. (Refer to 28 - DTC-Based Diagnostics/MODULE, Body Control (BCM) /Standard Procedure).
U110CU110C-LOST FUEL LEVEL MESSAGE
Always perform the PRE-DIAGNOSTIC TROUBLESHOOTING PROCEDURE before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
U110EU110E-00-LOST AMBIENT TEMPERATURE MESSAGE
U1110U1110-LOST VEHICLE SPEED MESSAGE
U11BCU11BC-LOST BRAKE SWITCH MESSAGE
U11E4Transmission Control Module (TCM) (8HP50/850RE) - CAN Communication Messages Missing
Transmission Control Module (TCM) (8HP75) - CAN Communication Messages Missing
U1412Powertrain Control Module (PCM) - Implausible Vehicle Speed Signal Received
U1412-00
Orca
