2014 ram 2500 6.4L ABS issues
DaveRam2500
Buffalo
I had my ABS light come on about a month ago. I scanned it, said right front ABS. (I’d have to go back for the code, forgot off top of my head). I changed the sensor. Didn’t work, changed the hub assembly to MOOG. light didn’t go away. Checked voltage. Old sensor on driver side was reading high. Cleaned up sensor and light still on. Replaced driver side hub with MOOG as well. Just took for test drive. Light still on, haven’t scanned again yet, traced wires, can’t find bad spot on wires. ABS light kicks out traction control and 4WD when on. Im scratching my head here. Anyone have this issue ?
1500ram12
5.9L Cummins
Try disconnecting the battery for about 10 minutes to see if it clears the code. If your scanner can clear it then use that also
2018 2500 6.4L Tradesman
DaveRam2500
DaveRam2500
Buffalo
I didn’t add in my OP, I actually just got back home and reconnected my battery (ran out for 15min) and turned it back on and the lights still on.
1500ram12
5.9L Cummins
Check the fuse if you haven't
WY-Dave
Cheyenne, WY
6.7 CTD
you need a reader that can do ABS. The plain reader will give you the location, but the ABS one will tell you more detail. I had a Jeep with the same symptoms and got an "implausible" error. It turned out to be a broken wire the first time. Then same thing but intermittent. What happened is the wire broke but not the insulation, that one was a bear to find.
Harleyhog
Canada
Hi I have a abs light coming on my 2011 dodge ram I can shut it off and start it up again and light goes out till I hit a bump again, code saying right rear wheel I'm thinking a wire .
