2014-Replacing Rear Shocks... 21mm crows foot for the job?
bmg97
The youtube video I watched made it look like quite a job. Pulling the hub, dropping the control arms etc.
Me too. Was hoping someone had some other experience / easier way
Gary2
S Jersey
Front isn't bad . Some people have you remove more parts than needed. Only thing I had to disconnect was , sway bar end link upper end. Pop tie rod and upper ball joint. Wire up the brake caliper so it don't hang by the line. I usually put a jack stand under the front cross member favoring the side you are working on. Remove tire. put floor Jack under the control arm to support it near lower BJ while you remove all of the fore mentioned items . then undo the 3 15mm nuts on the top of strut and the bottom strut bolt . lower jack and remove strut. start to finish should be less than 45 min per side to swap. if you are swapping springs add 5 min . Leave sway bar end links off until you are done and truck is sitting on its tires then do both sides
Loudram
Just a sinner saved by grace
South Jersey
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Are the rear shocks the same for 2WD and 4WD?
As far as installation goes yes they install the same way. As far as choices you'll see a lot more options shopping the 4x4 side even if your truck is rwd only.
mpicc84
North Eastern, PA
I just did this. After an hour and a half trying to come from the opposite side, across the top of the fuel tank with about 4 different sockets and elbow combinations, I ended up heating a wrench up. I wish I knew about that kit for sure!
firefox9
