2015 2wd 2.5 MAXTRAC Coil lift UCA questions
1bad15RAM
Got a 2.5 MaxTrac front coil lift & 3/4in rear spacer on the way for my 2015 ram 1500 2wd. Will I need new UCA or is it only 4wd having UCA problems?
ramittome
Gonzales, LA
What he said!
But if you do decide you want to change them, I'll be taking my Mevotechs off this weekend. Decided to go a different route. Passenger side is 13 months old, and painted, driver side will be brand new in the box. My ball joint had broke so bought a new one that's coming in this weekend, but I've decided to take them off. PM me if interested.
1bad15RAM
Thanks for the info. Should I use spring compressers or unbolt the uca to remove it? I dont want to be busting ball joints loose unless i really have to.
