2015 Ram 1500 suddenly stopped working
BigSalUSN
Norfolk va
So i went to work one morning truck started up fine drove to work and drove home from work when i was about to leave somewhere else i went to turn the key and nothing… lights a/c and dash still work but doesnt even crank so far i changed the alternator, serpentine belt, new battery, and starter relay fuse i also bought an obd2 scanner but no codes seem to pop up someone plz HELP!!
Jim BB
Hamilton ,ON
2019 Ram 1500 classic Express
have you checked all your grounds and the connection at the starter !?
BigSalUSN
BigSalUSN
Norfolk va
No sir i havent i’ll look into that tomorrow after i get off of work thank you
ibike
Tennessee
Look in the drivers side front wheel well. Take a long heavy metal rod such as a breaker bar and rap on the starter solenoid making sure not to hit the battery cable. I just replaced my starter with the exact same symptoms. Rapping on the starter solenoid will at least get you going till you can locate a starter. Mine took a week to arrive and came to Tennessee from Colorado.
Orca
