BCMark
Ok, I'm finally about to start into this tomorrow. I have done the stereo myself in the last 4 cars I've owned so while I am still fairly new to this, I am not completely inexperienced. This will be the most involved build I have done, however still won't be as crazy as many I've seen. I just don't have the fabrication skills or tools to get into anything too wild.
I'll try to keep this log updated each night as I go, I may not get a lot done tomorrow because of family commitments but the next few days after that should go pretty well. I also have a cat-back exhaust system, S&B Intake, and some plasti-dip coming in the mail over the next few days so this may turn into more than just an audio build log
I plan on running the stock head unit to an Audison Bit Ten D which will control a simple 2-way active + subwoofer system. I'll probably leave the stock rear door speakers in for the ability to fade to the rear for some fill, if I ever find I need it for passengers in the back.
I am going to be sound deadening as much as I can, and have done a lot of research in this area. My plan is to do as much as I can with Dynamat, CCF (closed-cell foam), and MLV (mass loaded vinyl). I have 104 square feet of Dynamat Extreme and a 50 square foot roll of B-Quiet Ultimate in case I run out of Dynamat. I also have 2 - 50 square foot rolls of 1lb per square inch MLV. I am going to start with the doors, then the floor and back wall. After that I'll see how much I have left and if i can get some of it onto the inside of the firewall. Still debating pulling the headliner as I'm a little nervous tackling that.
For components:
Audison Bit Ten D Processor
Morel Virtus 602 2-way Component Speakers
2 x Image Dynamics IDQ10V3 10" Subs wired for a 4ohm load each
2 x Hertz HDP4 Amps
- 1 @ 150w x 4 (4ohms) for the mids/tweets
- 1 @ 500w x 2 (4ohms) for the subs
Fox Acoustics Dual-10" Sub Box for under the rear seats
Knukonceptz Wiring and Terminals
Dayton Omni Condensor Mic and HP Netbook for Tuning
I have run the Hertz HDP5 in another build and was extremely pleased with the power and quality out of such a small amp, looking forward to seeing how 2 HDP4s perform. I have also used Morel speakers in the past and loved the rich sound from them. They were the Dotech Ovations I used in the past and apparently the Virtus line is just the newer version of the same.
Here is my starting pic of the gear waiting to be assembled/wired/installed.
And one of my truck:
For components:
2 x Hertz HDP4 Amps
