Ok big update of progress over last 2.5 days. I am finally onto the tuning stage as of this morning. Sounds amazing even with hardly touching it, had to adjust the tweeter output a bit as they were definitely overpowering everything with only being a few degrees off-axis and very close to the listening position. I will say though I don't find the Morel tweeters harsh at all, they are a bit bright but very musical. This is already the best sounding system I have ever done and can't wait to see what I can get out of it with enough time spent tuning
Here are some pics....
Tweeter install isn't anything too fancy, painted sails to match and used the supplied pods that came with them. Adjusted positioning to where I think they sounded best.
Definitely a PIA running the wiring through the doors for both door speakers and tweeters.
Not the best pic of the amp rack and it's a little bit of a challenge getting to the adjustments on it. I might actually redo that at a later date and move it higher. Just a tip for anyone planning an amp rack behind the rear seats, try to mount it from at least 1/3 of the way up the wall if you want good clearance and to make it easier to get to the wiring/settings!
Bit Ten is "sitting" in the center console storage bin right now, but will have the wiring routed a little cleaner and the unit screwed down. Also building a cover plate with spacer legs on it to sit overtop of it so that I can still use the top half of the bin for storage. I decided not to even install the Remote for it right now as I am quite happy with everything the way it is and hate the idea of needing to use a different volume knob than the one on my head unit. I set the gains on everything so that I have full use of my Head Unit volume from 1-20 without distortion and a plenty loud enough output (unbelievably loud at 20 but still crystal clear!).
Fox Box assembled quite easily with the provided instructions and fits like a glove. I did have to make some adjustments for the subs I chose as the cut-out in the Fox Box is 9" wide and I needed 9.6". No problem with depth though and once I cut the hole a little wider it fit great. Overall pretty impressed with the design and output of the Fox Box, for the price I don't think you could find a better box for our trucks. Also handy that it comes with the 5/8" seat spacers, which when installed allow you to fold forward the rear seats but still lock them in place when lifted back up.
