2017 2500 6.4 gas need EFI tuner
drago
Hello was wondering if any one had info on a efi tuner for my truck?
2017 2500 6.4 gas engine.
Thanks
monteholic
6.4 hemi
the ECU is locked on 15-17 rams, you will need to purchase and unlocked ECU and a tuner
huntergreen
lots more dollars. eventually, companies will figure out how to unlock and you will just need the tuner.
D
drago
Just did a BDS 5.5 lift with air ride and 37 inch fun country tires. Has 4.10 gears want to correct my speedo and going to change exhaust.
Diablo said fees months. I had 2015 2500 ram diesel with bully dog. Diablo said it will come with ecu and tuner.
Why do you need it? What are you trying to achieve?
There might be a better option.
Andrew09HEMI
First, post pictures of this beast!!! Second, the tuner will definitely waken that 6.4 up, Im running the 93 tune with some minor tweaking and its much more responsive. Well worth it
Ram-engineer
hemi 6.4
Yes, the Diablo Trinity will be a big difference but that is just a canned tune you need the ECU as yours is locked and get a custom tune for your tuner you will be very happy. I have a 2016 6.4 that I have done the very same tune setup with and it was love driving it off the lot now I can break the tires loose in 2nd gear driving on dry pavement.
Sent from my Pixel XL using Tapatalk
