2017 Ram 1500 Oil Temp Sensor
MurderHemi
Indiana
Where is the oil temp sensor located at for a 5.7 Hemi? I had a Hellcat bottom end swap done and the oil temp is not reading anything. Trying to track it down and see what the issue is.
Thank You
MurderHemi
MurderHemi
Indiana
Right near your oil filter , one is pressure the other temperature .
After investigating this is the only thing I see. Maybe they didn’t install one at all? Appears to be a plug up above the oil filter
jws123
nj
Whatever bottom end they used may not of had it installed there will be a cap/plug you un screw then you can re install a new sensor if its not there cant tell from your picture.
MurderHemi
MurderHemi
Indiana
That must be it then. I bought the hellcat bottom end used then had it rebuilt. This shop missed many things I am now fixing so it wouldn’t surprise me if they just plugged that port and didn’t transfer my sensor over.
I think the oil pressure sensor is mounted facing towards the front above the oil filter and the oil temp sensor is mounted above the filter and faces towards the pass side fender.It's tough to tell,but it looks like the sensor is there,but might not be compatiable with your truck if it's the hellcat sensor.You'd have to compare part numbers.
I think the plug you're looking at,is the block drain
MurderHemi
MurderHemi
Indiana
Ok I will look a little harder then. If the oil temp is about the filter and facing the passenger side it would definitely be harder to see.
MurderHemi
MurderHemi
Indiana
My Hellcat block ended up having a plug put in where the sensor went when it was rebuilt and the shop doing the install must of not caught it. After looking closer I spotted it and got my new pressure sensor installed. IMG_3146.jpegIMG_3149.jpeg
reyzapien88
