2018 ram 1500
KcDieselTech84
kansas city, missouri
Hello all, I'm new to the group. I have a 2018 ram 1500. im trying to install a factory brake control module and switch. What all items do i need to complete the process on the computer side? Cables and such. Im seeing there is a security bypass cable on alfaobd website. All that I need is the security cable, alfaobd download and a cable from pc to obd2 port correct? Any help is greatly appreciated.
Atcer2018
Virginia
I don’t know if the newer version of AlfaOBD is more windows friendly than the older version. When I went with Alfa back in 2019 the PC/Windows based version had little support and not much use by owners here. Most of the YouTube vids I’ve seen around Alfa use the Android version. I originally purchased the windows version and after tinkering with it for a few hours emailed the contact person and asked to get the android version instead. Just food for thought.
reddawg67
Winder ,Ga
A cheap android tablet will work I got one off OfferUp for 20 bucks and as always backup your files each time you change something just in case you fumblefart it !
Atcer2018
Virginia
Same here, I purchased an old Amazon Fire tablet from a coworker and even though it’s old and slow it works perfectly with Alfa.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Just bought a '16 1500 Sport and am using the AlfaOBD program on a Windows 10 laptop and the OBDLink MX+ (bluetooth). This set up works like a charm and is simple as can be.
On the '18, you'll need the security bypass cable. too. That's it.
The android tablet works well, too, but I like the larger screen. Just a personal preference. Plus downloading and saving the car configuration is much easier on the laptop.
Added the OEM brake controller on mine, too and after installing the physical components, it took all of 5 minutes to do the programming. Works like a charm, but I think the Tekonsha Prodigy 3 I had originally, worked as well and offered more fine tuning options. But was a PITA to locate a good mount location without drilling holes in conspicuous places.
Orca
