Good morning, I checked voltage in the right place this time 11.92v with my cheap multimeter. Replaced the media hub, still no usb connection or blue lights around ports but the aux is now connecting and able to play music from my phone. Any thoughts on a next step?I do remember seeing those faint numbers on the connector. I will give it a go and check under seat connections as well. Thank you all so much, I appreciate it!
If you ha e power to the hub, check wiring USB connection, it's a mini-USB, there's one cable that runs from the center console down to just at the edge of the center stack. Check that connection to see if the USB is good there, if not goto the back of the radio.Any thoughts on a next step?
How do I know if the mini USB is good? I found that connection under the driver seat and it seems solid, has continuity to the media hub mini usb. I also checked continuity between the 8 wires running toward the media hub for the other larger harness. Does that mean I need to trace wires from under the drivers seat to the back of the radio? Could it be some kind of programming required? I hope I'm learning something but mostly think I'm clueless and stumbling around.If you ha e power to the hub, check wiring USB connection, it's a mini-USB, there's one cable that runs from the center console down to just at the edge of the center stack. Check that connection to see if the USB is good there, if not goto the back of the radio.
I use a mini USB adapter to be able to plug it into my phone, was lucky enough to one in my spare parts and pieces.How do I know if the mini USB is good?
I have the same problem, but I notice that, since the Uconnect app is no longer functioning, is when my car play stop working, probably that’s the issue maybe is not the cable or the phone, is no longer supported with the app,
Hope that helps
Hey I was having the same issue randomly , worked with different cables but only for limited time .I came on here to figure it out .Did a bit of digging then I tried my wife's phone ,worked perfectly fine with all cables ...turned out my phone had a ton of updates awaiting.Almost all apps from my Google Play store ....I did the update on all of that then checked if my phone was updated to the latest software ( it was not ) . Completed the update restarted my phone and plugged it back into the truck and it works perfect....charging and Android auto.....So I'm having issues with my USB connection from my phone to my 8.4 u connect. About 2 months ago it worked fine then started giving me issues. My phone connects no issue via Bluetooth. When I plug the USB cord into the console port and into my phone I'll get the charging symbol on my phone for about 30-50 seconds then it goes to battery usage again. It'll to that intermittently until the phone is unplugged. The radio will show no device connected. I've tested the cord with a charge brick and a computer so it's not the cord. I can plug my phone brick and use the cable with the 120 plug on the dash no problem. Is there a fuse I should check or do I need a new media hub? Just looking for a place to start. I would like this to start working again so I can display google maps on my radio since I have a non-navigation radio. Thanks in advance
