- May 27, 2023
- 1,692
- 1,829
- Location
- Sthrn AZ
- 2023
- 6.4 Hemi
Here is something I have never run into before. I have many years of towing experience and maintained a CDL until I retired. Under normal circumstances, the tire pressure on the door pillar is what is suggested for everyday driving, i.e., 35 PSI all-around, even though the max on your tire sidewall says 65 PSI. My new RAM 2500 door pillar says 75 front/80 rear, and the max on the sidewall is 80. I looked through all the data I could find and that is apparently what it's supposed to be. This is not what I have known from experience. The door pillar is for normal driving and you add PSI according to your load, up to your max PSI on the sidewall, which you pretty much never get to. The manual even says (paraphrased), "The tire pressure indicated on the door pillar is the recommended pressure up to your maximum GVWR." If I were to go by the calculations that I know, it should be running somewhere in the 40 PSI range on every tire, but if I drop it that much my TPMS will come on and not go away until I air it back up to 80 PSI again (so says the manual) For info, I have:
2023 RAM 2500 Tradesman, 2x4, 6.4L Hemi, Reg Cab, LB, GVWR 10,000# GVWR, Payload cap. 3913#, Towing cap. 15,540#, Tires: Firestone Transforce 245/70R17E 119/116R
Anyone got an input?
