- Dec 7, 2020
- 6,891
- 17,445
- Location
- Minneapolis, MN
- 2017 2500 Laramie Crew Cab
- 6.4L HEMI
Wrong - the CP4-2 is used on larger engines. The CP4-1 is used on smaller. I currently have a recall for my 2020 EcoDiesel with the CP4-1 pump. The F150 3.0L Diesel also uses the CP4-1
Wrong again - The CP4 is a higher pressure version of the CP3. It is less expensive, lighter, and more efficient. It's main failure mode is cavitation and lack of lubricity. This is why the lack of a lift pump (higher differential pressure) ABSOLUTELY contributes to the failures. As you said -WELL DOCUMENTED BY THIS POINT. Adding lubricant to our low sulfur fuels makes these pumps last. I'll let the lawyers figure out if that's worthy of a class action suit.
I read up on the Gen3 ED before I bought it. You should do the same. There were failures on the Gen 1 and 2. Gen 3 has been very good. Unfortunately, they are discontinuing (I would have bought another).
On the flip side, you are pinning your homes and dreams on a Gen1 3.0L Duramax where you don't like the ride quality or Fit/Finish. Sorry, but I wouldn't buy a Gen 1 anything (including Toyota) particularly if I didn't care for the rest of the vehicle.
For your edification - here's the TSB list for the Silverado 1500 with the small diesel. Interesting that the have some related to "excessive fuel contamination" and "fuel additives". Doesn't sound anything like a high pressure pump concern - or does it?
Silverado 1500 3.0L Diesel TSB
I read the comments and links from the members here. I was speaking to Gen 1 and Gen 2. ED is being discontinued. Why would I consider vapor-ware?
