275/60-20 tires on 20x10 wheels?
DirtyMopar
Ohio
I just recently bought new tires 9 months ago and they are 275/60-20 tires. I found a good deal on moto Metal wheels, but they are 20x10. I wasn’t sure if the tire size I have on there now will fit on 20x10. Anyone have a clue? Thanks
quietpeen
2021 TRX
Hellcat
it will mount, whether it fits properly or "looks good" comes down to personal prefernece.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Perfect fitment IMO with OEM flares. Only have had the setup on for a couple weeks and haven't had time to really clean up for photos, but here's one without tire letters. These are MO962 btw.
Check out custom offsets as there's a red ram without flares that still looks great. I mentioned in another thread that the price of tires drastically reduces and actually have better grip because more tread is contacting the ground than my 13" wide previous setup where you'll get bulging and center tread wear.
D
DirtyMopar
Ohio
What’s the offset of your mo962? So, 275/60-20 will be stretched on 20x10 wheel? Will that hurt anything daily driving and towing loads etc?
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
Offset is -24
Absolutely not as long as you are properly inflated and under your gross vehicle weight requirements on the load.
275Mm=10.8” and although not recommended by basics tire standards, a 10” wide wheel is actually 11” outer lip to lip. So you almost have a square setup but tires all run different by brand/model.
D
DirtyMopar
Ohio
Offset is -24
Do you have more pictures of your wheels? I’d like to see how they stick out past the fenders.
stimpy433
IOWA
I have 295/60R20's on 20" x 10" rims with a -25 offset and they stick out 2" from the fenders. Here's a picture of them before I installed my fender flares.
purcell1
hemi
Defiantly not the perfect fitment as stated above. But it’ll work. 275 are meant for a 9” rim. Unless you like the little stretched look.
