275/60/20 vs 275/55/20 tire size
Frankwhoa
LA
How many of you have dropped down to a 275/55/20?
I just bought a set of take offs with 14 miles on them from a 2019 1500 Laramie for a bargain.
What is the best way to update speedo and tranny or does it matter with that little size difference?
Should I let a tire shop or the dealer do it?
Almost forgot, I will also need to relearn the tpms... best way for that also?
Thanks guys
CincyCuda68
Ohio
AlphaODB is the best value for programming a lot of functions on your truck, tire size and tons are just a couple. That being said, not sure that little difference would make you too far off. I went from stock tires to 35x12.5 and the difference was about 2-3 mph.
Frankwhoa
Frankwhoa
LA
Thanks, what about shift points and performance from using a smaller tire?
CincyCuda68
Ohio
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
I ran a set on my 11 Eagle GTs for about 50 k. Speedo was off 3 mph.
Hated how they drove.
Maybe it's because they were 55s
Never again
Fatbob Frank
Mc Gregor, Iowa
6.4L
I did the opposite.
Went from 275/55-20s to 275/60-20s.
No tune or reprogramed speedo.
I notice on the 'check your speed' radar signs they have around town that I'm about 1mph fast @ 35 and 2mph fast @60.
Not enough to spend the money on a programmer IMO...
BWL
Embrace the skeptisism
BC Canada
275 60r20 is an available stock size so you may be able to get the dealer to change it if you go in for any recalls that involve plugging it in to flash it for minimal or no charge.
grizzstang
Calgary, Alberta Canada
You can use an AEV Procal to adjust your tire size.
It also does a few other things and does not require you to get an unlocked PCM.
I used one on my 2017 for tire size adjustment and it works great.
Make sure you get the right one. One is for Rams 2013-2017 and one is just for the 2018.
https://www.aev-conversions.com/product/ram-procal/#year
