Hey guys,
So I am finally in the market for new tires. Below are my high-level truck specs
Truck Specs:
2013 Ram Hemi Sport
4x2
3.21 gear ratio
20X9 stock rims which I am keeping
I am going to be adding a 2 inch front level for the tires & a Hemi Fever tune after the tires are on.
I am going with the Toyo Open Country R/T's. Here is my question(s).
- I cant decide between the 275/65/20 OR 33/12.5/20. Can anyone share pros/cons for each tire?
- I want to try and fill the wheel well as much as possible without rubbing Or adding a spacer. Which tire would be best for that?
- The 33/12.5/20 are about 7-9 Lbs heavier per tire than the 275's. Will that cause any issues with my current gear ratio?
- IF I go with the 275's will that cause issues with my 3.21 gears?
- Feel free to share anything else that would be helpful that I am not thinking about.
Thanks in advance for the insight! Looking forward to the comments
Truck Specs:
2013 Ram Hemi Sport
4x2
3.21 gear ratio
