2nd Gen Belltech 1" drop spring not to specs
low95ram
Louisiana
I have a 1995 exd cab. Installed Belltech 2" drop spindles and 1" lowering springs. After the spindle install with the factory springs the height measurements were all even front and back. I then decided to install 1" drop springs which now has it uneven in ride height. The passenger front is a whole 1 inch difference rather 1/2 inch like it suppose to be. This has the drivers side rear a 1/2 inch lower than the right which is very noticable.
I called Belltech and asked what the specs were on the springs and they said 3/4 to 1 inch difference. I argued and told then this is incorrect specs that it should be 1/2 inch. They're tech support is horrible!
My question is has anyone had this issue? I read on another forum that someone was going to try to swap the springs. Has anyone done this and what were the results?
JustinRam1500
