3.55 -> 4.56 gear change progress
kg93
AZ
I got started on gathering my parts for the swap. So i figured i would make a thread showing my progress and prices.
Ordered:
2009 Front Diff - $340
06-11 Right output shaft(extra...unfortunately)- $161.59 <--avoidable expense
Motive Front master rebuild timken bearings - $145
Motive 4.56 Front gears - $200
ZF Lsd - $285 - thanks jcstacey
4.56 moes motive zf rear gears - $279 thanks matt!
rear master rebuild kit - $99.99
55-05-4594………….…front diff. bracket, driver / rear $32.79+15 shipping :( - superlift
Need to order:
Nothing!
Total: $1558.37+/-
+install
For a quick minute i actually thought about trying to do the front diff myself since it will be out and i can take my time, but i dont want to screw anything up. Couldn't find a video for the 8" diff specifically either
matt.davidson09
2013 RAM 2500 Laramie Mega Cab
6.7L Cummins
Nice! Following for info and progress. Good luck!
Mauzz
One of my jeep buddies is actually a professional mechanic and even he still has the gears installed for him. We've literally built suspension parts in the garage but there is just too much to ensuring the contact pattern is correct with appropriate backlash, bearing tension etc..
The War Wagon
da' 'BURGH
318 Magnum
I did it on my '92 RC. You'll like the get-up-&-GOfactor once done, and with a more modern truck, newer engine, lower miles, etc., you'll hafta be careful not to crush cars at stoplights when you hit the gas! icon6.gif
kg93
kg93
AZ
Hahah I can't wait. Honestly it doesn't feel weak and I can still accidentally smoke the tires with the 3.55s and 37s. So when I get the lsd and 4.56s...ohhhhh boy will I have to watch myself.
It should be worth the 2.5-3 grand I'll be spending LOL
Yeah that's what I'd be worried about. Maybe one day when I'm more experienced I'll try doing it on something older, for now I'll just drain my bank account [emoji23]
Sent from my LG-H900 using Tapatalk
kg93
kg93
AZ
Side note, I can't figure out if I'll need older cv shafts. Some people say yes some say no
kg93
kg93
AZ
got my front diff and lsd today (thanks jcstacey)
but im kind of pissed off about the differential. I got it for 340 shipped but when i opened it up its missing the right(passenger side) output shaft...yet the ebay ad said no such thing.
I messaged them tonight, ill see what they have to say. Its really annoying since the output shaft new(all i can find) is like 170-200....and who knows what else ill need now.
R.L.K.
Bristol , Tn.
Subscribed.
Looking forward to seeing you complete this . I may do this one day if I go up to 37s.
kg93
kg93
AZ
So the wonderful people in ebay are saying that the right output shaft is a bonus piece when buying a differential. ******* now I'll have to find a used one or try to fit the 14 output shaft into the 09
Mauzz
You didn't want to actually USE the differential right? You just bought it to look at... :****sweak:
6.7CumminsDrvr
The Dude abides………
Georgia
So what are the plans for the front diff out of your truck? I might be interested............for research purposes.
kg93
kg93
AZ
Once I get everything figured out I'll definitely be selling it
kg93
kg93
AZ
So now that I have the differential I was able to see some differences that I'm not sure how I will fix without custom brackets which is more $$$ lmao
People who have done this swap feel free to chime in.
I can order every superlift bracket for the 09 lift but the angle will still be off(see the pics)
What baffles me is the driver side bracket part numbers are the same for the 09-11 superlift and the 12-16 lift..but obviously they are different.
09 diff
Diff on my 14..tough to get a pic
That's the rear drivers side, it's on a angle not straight like the 09
kg93
kg93
AZ
At least you know where to get the 3rd member bracket from , thanks to ( the goldenone )
i tried getting him to get one made for me but he never answered. Shame.
Im not sure why the superlift brackets are the same, makes no sense. Im not sure if i want to use a rcx bracket because of the potential difference in geometry between the lifts. Although since it will need to be cut and welded anyway maybe that wouldn't matter.
R.L.K.
Bristol , Tn.
Did you try "Billy" at Gears Unlimited in KC , Mo.
http://www.ramforum.com/showthread.php?p=1197265
Probably right since it would require cutting & re welding it wouldn't matter rcx or superlift brackets .
Would be nice to get Billy to make you one though !
If you get Billy on the phone , he could confirm the CV shafts as well , and if you still need the passenger side components not received from the ebay seller he may locate that for you as well , could be a one stop shop !
Hell where are you located ? May be worth going there for the work and just doing the 500 mile oil change & inspection yourself or at another shop near you that Billy may recommend. .. just a thought .
R.L.K.
Bristol , Tn.
Just seen your in Jersey , should be plenty of shops to choose from there to get this kind of work done , you may have to take out another mortgage on your home or sell your first born
But with people crowded like ants in that part of the country there should be plenty of reputable gear head shops in close proximity.
kg93
kg93
AZ
good call I didnt even think of calling the guy myself! But yes i have a shop lined up but they dont know that they'll need to weld a bracket together yet. Things like that definitely aren't cheap over here!
kg93
kg93
AZ
so prior to getting an answer from billy ive been trying to find the spline count on 12-16 cv shafts, i cant seem to find anything. early 2000s to 2011 have a spine count of 33 male 29 female with an overall length of 23 3/4"
kg93
kg93
AZ
Update from billy, i emailed him since i didnt have time to call him. Haven't discussed getting a bracket shipped to me yet but he said the cv shafts are the same and all i need to do is switch the drive shaft yoke. So im guessing that the driveshaft yoke from the 14 dif will fit on the 09 diff
jovtra
