@Ramsteen23 hadn’t even considered the 295’s as I thought they may rub. Good to know it is very minimal even in aero. Do you have any pictures of these on the truck?
So I just re-checked my ride heights in front at Normal Ride Height mode and Aero mode with the 2.5" lift kit to ensure I'm giving you accurate info. Measurements are from level ground along center of wheel to bottom of fender since this is the only measurement I took at stock height in order to have a comparison. I later learned it's more accurate to measure from the center of the wheel hub to fender.
Normal Ride - 40" (24" from center hub)
Aero - 39" (23" from center hub)
Normal Ride (at stock) - 37.25" from ground
Keep in mind all of the measurements have some slight variability depending on how level the ground was but it does give you an idea of how much of a difference the 2.5" lift does make. Since the Aero mode with the lift kit is still higher than the stock Normal Ride Height I decided to measure it at Entry/Exit mode which ended up being closer to the stock Normal Ride Height at just under 37.50". The good news is there is still only minor rubbing at this height see pics below.
Hope this is helpful -
Normal Ride Height with Lift Kit
Entry/Exit Mode with Lift Kit
