wickedwhite2012
Can someone tell me if they have a after market 4.10 gear for the '12 1500?
I have one ready to go....
Unfortunately, no. Nobody makes an aftermarket limited slip either for the 2011-up trucks. The axle shafts are different lengths, so if you try to install an aftermarket LSD unit, 1 of the axle shafts will not line up correctly. If you need a stock LSD that is already machined and ready to bolt on a set of aftermarket gears, then contact Josh at Modern Performance Engineering. He sells this unit for about $850 shipped. This comes machined and ready to go. Otherwise, the stock LSD unit runs about $600, and then you would need to run the very expensive factory 4.10's.
this new crap changeup on the front ends is all thats holding me back from a larger lift and 37s, its really agravating. im still lifting my truck higher, but i dont want to run 37s with 3.55 gears. i know of a lot of people doing it but i want to keep my feeling of power too the wheels while driving.... we need a after market kit for the guys who dont like to leave their stuff stock.
