4 inch lift help
Jdeere
Finally decided to go with a 4 inch lift for my 2014 RAM 1500. Was looking for recommendations for kits that are under 2 grand but are still solid. Also if anyone has pictures of their 1500's with a 4 inch lift I'd love to see them. Looking to run 35/12.5/18 so don't know if I can go with the rough country lift regardless. Thanks in advance!
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Here is mine with 4" Mopar lift (rebranded Super Lift) and 35x12.5r20s. The dealership is more expensive than you'll find other places. A lot of people like the Zone lifts too.
Jdeere
Jdeere
Here is mine with 4" Mopar lift (Super Lift) and 35x12.5r20s. The dealership is more expensive than you'll find other places. A lot of people like the Zone lifts too.
Love the truck, thanks for the pictures! Will check them out
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Thanks. You should post this in the lifted section too if you haven't already.
JB1
Houston, Texas
check out this thread, mpittman has pics of 4" with 18's, really nice setup
http://www.ramforum.com/f40/finally_finished_-_4_bds_w_bilsteins_@_1_4_a-96212/
http://www.ramforum.com/f40/zone_bds_4in_w_billsteins-109188/
Jdeere
Jdeere
Reactions: JB1
JB1
Houston, Texas
no problem, when I saw you wanted a 4" kit with 18's I knew the exact truck to show you lol
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Jdeere check out the galleries at customwheeloffset.com too for ideas.
17CrewCab1500
Do you need to have Bilsteins with a 4" lift??
Ratket
Arizona-
I would suggest looking at all the kits . I’ve ran roughy country and Bds in the past... both where good. knowing what I know now.. read the instructions on the lifts and see which ones are less intrusive on the truck” Require less cutting, and the ones that give the most travel. Just my opinion.
joeygster
Ancaster, Ontario
No, as long as you're ok with keeping a bit of the front rake. The kit raises the back 3" and the front 4". If you want to be level (no rake) then you'll need the Bilstein 5100's.
I was fine with the slight rake and my truck was brand new so the shop just used the front factory shocks.
14RAM4X4
Sweating somewhere in South Texas
2015 RAM 2500 4x4
6.4L Hemi
4" superlift, bils @ 1.4, 295/65r20s on stock wheels.
Just know that once you go with a 4" or bigger lift, there is NO going back. You have to cut off the lower control arm mounts to bolt up the diff drop craddle. Also, when I went with the superlift rear springs, I got more squat than I did prior to the lift when towing and loading up the bed.
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Did you end up changing from the Superlift springs? If so, what'd you use?
14RAM4X4
2015 RAM 2500 4x4
6.4L Hemi
Nope, upgraded to a 2500.
There are a few things you can do to offset the squat with the softer springs
1) air bags
2) Sumo springs
3) Stiffer springs like Tuff Truck springs + coil spring spacers
Not sure if anyone makes a stiffer coil spring that also raises the rear.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Hey Bryan, are these stock Mopar flares? I have same color truck and these look nice on yours.
- Jack
RAM DRVR
Mid left coast - Oregon
CTD
Just got my Tuff Country 4" lift installed today..........
Not great pics, but what I got today.
tigger54
