4" or 6" Lift with 35's
Discussion in 'Lifted' started by ericbrums89, Nov 10, 2017.
  1. ericbrums89
    ericbrums89 Junior Member
    15
    Sep 5, 2017
    Ram Year:
    Engine:
    Hey guys!
    I am new to the forum as I just bought a 2017 Ram 1500 Laramie Crew Cab 4x4. I am starting to save up the money for a lift, but I am having a hard time debating between a 4" or 6" lift. I know for a fact that I am wanting to stick to 35x12.50 tires, but I don't want to do a 4" and regret not going to a 6" or going with a 6" and thinking the 35's are too small. Any thoughts? Pictures would be very helpful too. PS. I want it to sit perfectly level at either height.
    Thanks,
    Eric
  2. 14RAM4X4
    14RAM4X4 Senior Member
    316
    88
    Aug 19, 2014
    Sweating somewhere in South Texas
    Ram Year:
    2015 RAM 2500 4x4
    Engine:
    6.4L Hemi
    So, here's the kicker.... a 4" or 6" lift will leave you with the factory rake. So if you go with a 4" lift, then add the bilstein Adj struts, you can get close to the 6" lift and remove the factory rake.
    I had a 4" superlift and added bilsteins set at 1.4". So that's 5.4" lift and I only had about 1/2" of rake. You could do the 2.1" setting at be slightly nose high, but only by about 1/4"
    Crazydrummer74 likes this.
  3. MarshRam
    MarshRam Supporting Member
    679
    246
    May 24, 2017
    Ram Year:
    2014 SLT 4x4
    Engine:
    6" lift. I probably sit nose high about 1/4" with this procomp setup, but you really cant tell. Sorry, no pictures on level ground. Lift shop showed me a small spacer I could remove to bring down the front a little and may get me level, but I'm totally happy with it and I was initially determined on being perfectly level as well. If you are even thinking you may regret not going up to 6" lift, then just do the 6". Just that 2 extra inches will give it a different look.
    Papi4k likes this.
  4. Graygoose
    Graygoose Diplorable
    7,175
    1,563
    Nov 21, 2011
    Oklahoma
    Ram Year:
    2015 Silver CC
    Engine:
    4" if you want to park in the garage LOL
  5. Solid State
    Solid State Senior Member
    581
    241
    Apr 18, 2016
    Ram Year:
    2011 Bighorn
    Engine:
    6" zone with 35's, still fits in garage :favorites13:
    KiltedCelt01, jmont75 and Graygoose like this.
  6. Rzrman328
    Rzrman328 Senior Member
    34
    5,769
    2,883
    Aug 25, 2014
    The treeline
    Ram Year:
    Engine:
    6" and 37's...still fits.
    Solid State likes this.
  7. blackbeautyhemi
    blackbeautyhemi Senior Member
    29
    1,672
    599
    May 19, 2013
    Lewistown, PA
    Ram Year:
    Engine:
  8. JB1
    JB1 Senior Member
    1,825
    558
    Nov 3, 2011
    Houston, Texas
    Ram Year:
    Engine:
    First, in order to decide what lift will yield your "level stance", you need to measure the difference in height from front fender height to ground -vs- rear fender height to ground (or wheel center), most are about 3" higher in rear but it does vary.
    To answer your question, to fit 35's all you need is a 4" lift kit (any brand), or the 6/3 Zone/BDS lift kit.
  9. muddy12
    muddy12 Senior Member
    258
    119
    Jul 26, 2016
    Ram Year:
    Engine:
    6” with 35’s and still fits under standard 7foot garage door, as well as parking garage at work. Thinking about going to 37’s next time I need tires.
    [​IMG]
  10. bryan28
    bryan28 Senior Member
    883
    410
    Apr 28, 2015
    Middle TN
    Ram Year:
    2017 Laramie CC 4x4
    Engine:
    4" lift with bils at .7 and 35s
    JB1 likes this.
Share This Page
