Nocturnalsst
- Oct 2, 2015
- 22
- 0
- 2015
- 5.7
Surprised there are none listed for '14 or '15 rams. I'm interested to see how the 8 speeds do in the 1/4 with different mods
There are a lot of fast '14 Rams, but this list has not been updated in months. Our 2 fastest naturally aspirated 2014 customers ran 12.56 and 12.70 in the 1/4, and our fastest 2014 customer with nitrous ran a 12.10 in the 1/4.
The 8 speeds trucks can be very quick.
14 ram crew cab 8 speed
13.19 @ 103
Sent from my SAMSUNG-SM-N920A using Tapatalk
I don't believe in the hole break in thing just drive it lol. My truck is 2wd.What mods do you have? 4x4?
I am wanting to take my stock 2016 Ram but I have not even put the 300 mile break in on it yet. Kinda odd for me driven 200mi so far and have never even put the gas past half way. I think I have only gone into Aero mode twice now. Gawd I hope I'm not getting old.
Well you're wrong about the break in lol.I don't believe in the hole break in thing just drive it lol. My truck is 2wd.
Mods are:
Stock air box mod
Greene racing tune
Jba long tubes no cats
True duals dumped before the exhaust
170 thermostat
28" slicks
3.21 Gears with lsd
There are two very important things you must do to any new engine.
One is to mate all your bearing surfaces and ensure that they aren't deformed or damaged. This is done by using a conventional oil high in zinc and phosphorous and keeping the engine well below redline. Usually this doesn't take very long.
The second is to mate your piston rings to your pistons and cylinder liners. This is done by varying the load and rpm on the engine, and can take several hundred miles.
Mods are:
Stock air box mod
Greene racing tune
170 thermostat
28" slicks
3.21 Gears with lsd
You already know what I meantDumped before the exhaust?
I know you're one to argue lol but I've owned 6 new vehicles and drove all of them the same. I bought my 2012 mustang on a Friday and went to the track Sunday. Far as I know that mustang is still hauling ass today. The same goes with my current truck lolWell you're wrong about the break in lol.
The exact procedure is debated, and really there are a lot of variables that will determine the proper procedure.^^ Take this with a grain of salt.
Engine break in is one of THE most debated topics among professional engine builders, and it all comes down to what the new engine owner is instructed to do to not void whatever type of warranty they have to cover a possible craftsmanship quality issue.
In my decade of building race engines, I've seen all kinds of methods used to break an engine in, and I'll honestly say that with materials used today, and the quality of machining that's performed on components, there is no absolute.
Argue away all you want.
Good for you.I know you're one to argue lol but I've owned 6 new vehicles and drove all of them the same. I bought my 2012 mustang on a Friday and went to the track Sunday. Far as I know that mustang is still hauling ass today. The same goes with my current truck lol
Buying a new vehicle is different then building an engine to break it in. How many miles did you have on your truck when you bought it?Good for you.
But no one said not breaking in the motor correctly would cause catastrophic failure. It can, in very rare circumstances, but it's unlikely.
Rather, not breaking in the motor correctly can cause it to produce less power, wear out prematurely, and have reduced efficiency. These are all likely.
I worked as a ford/Chrysler tech at a dealership for 10 years. I did predelivery inspections on new vehicles. First off we had to drive more than 4 miles on the inspection. Whenever you test drove your truck you can not tell me you didn't go WOT. Customers come in all the time and drive the **** out of those cars to see if it's what they want. I know your an engineer and I'm some dumb tech that doesn't know anything about cars lmaoThe engine is new in a new vehicle?
At most the factory started the vehicle and let it idle with some mild driving. That should take care of getting the wear surfaces mated to each other. The rings still need to be broken in on a new vehicle though.
And it had like four miles on it when I bought it.
