Tranny problems 4th gen
Steviesunshine
Westbury New York
Hey all first post. I’ve had my 2017 ram 1500 sport since brand new. I’m at about 110000 miles and noticed that my mpg is getting horrible. I put the computer on the car and came up with a ****ton of codes with no cel showing. It’s the 8 speed tranny. I was wondering if anyone had something similar? And if so what was the outcome. I personally think it’s the tcm but I could be wrong
Car Scanner ELM OBD2
DTC report
Selected brand: RAM
VIN: 1C6RR7MT6HS706665
============1==============
P0732(00)
Raw code: 073200
ECU: Transmission control unit
Status: Test not completed during this operation cycle
OBDII: Gear 2 - incorrect ratio
============2==============
P0731(00)
Raw code: 073100
OBDII: Gear 1 - incorrect ratio
============3==============
P1DA8(00)
Raw code: 1DA800
============4==============
P1DA7(00)
Raw code: 1DA700
============5==============
P1DA6(00)
Raw code: 1DA600
============6==============
P1DA5(00)
Raw code: 1DA500
============7==============
P1DA4(00)
Raw code: 1DA400
============8==============
P1DA3(00)
Raw code: 1DA300
============9==============
P1DA2(00)
Raw code: 1DA200
============10==============
P1DA1(00)
Raw code: 1DA100
============11==============
P1DA0(00)
Raw code: 1DA000
============12==============
P1D9F(00)
Raw code: 1D9F00
============13==============
P1D9E(00)
Raw code: 1D9E00
============14==============
P1D9D(00)
Raw code: 1D9D00
============15==============
P1D9C(00)
Raw code: 1D9C00
============16==============
P1D9B(00)
Raw code: 1D9B00
============17==============
P1D9A(00)
Raw code: 1D9A00
============18==============
P1D99(00)
Raw code: 1D9900
============19==============
P1D98(00)
Raw code: 1D9800
============20==============
P1D97(00)
Raw code: 1D9700
============21==============
P1D96(00)
Raw code: 1D9600
============22==============
P1D93(00)
Raw code: 1D9300
============23==============
P1D92(00)
Raw code: 1D9200
============24==============
P1D91(00)
Raw code: 1D9100
============25==============
P1D90(00)
Raw code: 1D9000
============26==============
P1D8F(00)
Raw code: 1D8F00
============27==============
P1DDD(00)
Raw code: 1DDD00
============28==============
P1DD0(00)
Raw code: 1DD000
============29==============
P1DDC(00)
Raw code: 1DDC00
============30==============
P1DCE(00)
Raw code: 1DCE00
============31==============
P1614(00)
Raw code: 161400
RAMaway
Chesapeake, VA.
Hemi 5.7 etorq
Remove the harness that attaches to the TCU and inspect for corrosion
or heat related indications..Is the case grounded, does it pick up ground
from case or internal ground?? This is some place to start!! RAMaway.
thoffmann517
