Propanedr
- Apr 20, 2013
- 43
- 22
- Location
- Homestead & Sebring Florida
- 2013
- Hemi 5.7
Good morning and thank you for your input in advance.
Here is my question. Is it possible to have the engine timing off 180 deg ? how can i verify that i have TDC ?
This is what i have done:
brought #1 cyl to the top. (Driver side closest to radiator)
the #6 cylinder is at the top also.
set cam to 12:00 position via locating pin.
Set crank shaft to 6 o'clock via dot on lower gear.
Verified that crank shaft notch is close to the 2 o'clock position on oil pump.
Installed timing gear with phasher and lower gear at the same time.
Note: cam phaser has a limiter installed.
Installed new lifters which i soaked overnight in oil.
Next i installed the edelbrock heads.
installed rocker arms, made sure the long push rods were on the exhaust side.
installed timing cover.
installed ATI Harmonic balancer.
Hooked up ARH long tube headers.
next was the intake and valve covers.
plugged the coils in.
flashed the computer with Hemeifever tune.
Tried to start the truck:
after a few seconds the oil pressure came up to 45 ish lbs
truck never started. I heard a pop or two but thats it.
pulled a plug and hooked up a compression tester and found zero pressure.
Note: I did install the timing incorrectly prior to this and cost me 10 bent valves and new head bolts, head gaskets, etc....
I failed to torque down the cam bolt and sheared the locating pin when trying to start the engine.
I replaced the pin. This was fun, while the cam was still in the block.
The way i understand it, correct me if im wrong. The locating pin is just to align the cam with the phaser. The two parts are actually held together when the cam bolt is properly torqued down.
My fear is that ive got the timing incorrect again.
Thank you
Thank you
