5.7L Hemi spark plug change
Hemi395
Hemi395
Cape Cod MA
How similar to this (nice) write-up is the 2011 4.7? Pretty much the same procedure?
Not really sure to be honest. I know the 4.7s have 2 banks of plugs that need to be changed at different intervals. The steps I outlined regarding the removal and reinstallation of the plugs with antiseize and dielectric on the boots should apply to a 4.7...
Gordinho80
Monroe, NJ
2012 1500 Big Horn
Damn! The rearmost coil on the pass side is a ***** to get to! Otherwise, the change just went relatively smoothly. Completed in an hour and a half.
Old plugs...
ramportin1
Sickest member here
Oregon
Is the original plug link still good? they are listed as nickel and not copper
Ramnewbie
I don't know this for a fact, just heard it from someone else that got it from a sea foam rep. Run seafoam thru vacuum like a normal cleaning and let soak overnight, with engine cold spray a little deep creap around the plugs before extraction, no carbon issues tearing up threads. The specific vehicle they were talking about was a Ferd 5.4 with those crazy assed plugs, but wouldn't hurt the hemi either.
Sent from my XT1650 using Tapatalk
Hemi395
Hemi395
Cape Cod MA
Old plugs...
Tell me about it! I was expecting the driver's side to be the worst because of the brake booster but it wasn't nearly as bad as the passengers side was
Hemi395
Hemi395
Cape Cod MA
Oh man those Ford 5.4 spark plugs. Who would've thought it was possible to mess up something as simple as a spark plug?
Gordinho80
Monroe, NJ
2012 1500 Big Horn
My left wrist is still tingling from the contouring required to get that coil off!
Burla
2010 Hemi Reg Cab 4x4
Old plugs...
How many miles on those plugs? Do you use any fuel cleaners? Have to say from what I can tell gap and corrosion level looks good. Just the fact the sides are getting so corroded probably good to get them out just on that basis, bit looks like the plugs would still be operating good. Did you put any anti seize and/or di-electric grease when you put new ones back in?
Gordinho80
Monroe, NJ
2012 1500 Big Horn
Unknown mileage for those plugs. I just bought the truck last month, figured best to change regardless and know how old they were. Anti-seize and dielectric grease on new plugs.
Hemi395
Hemi395
Cape Cod MA
They are the correct plugs for 2009 to early 2013s but if you want to be 100% sure you're getting the right ones for your truck I would contact Benny at allmoparparts.com on here. He's awesome and gets back to you real quick
wyo.hemi
Colorado Springs
Has anybody used Bosch 6734 in a 13 or older? I have always had pretty good luck with Bosch.
Hemi395
Hemi395
Cape Cod MA
The 2013 and older trucks are very sensitive to what plugs are installed. I've had great luck with Bosch products as well but I've just seen to many posts on here and other forums about misfire codes being set from putting in plugs other than the Mopar ones. The 2013.5+ trucks are much more forgiving with plugs.
wyo.hemi
Colorado Springs
Great thank you.
jws123
nj
Just pulled the cheap autolite plugs out of my truck few days ago spent the $80 for the nkg oem ones and Boy what a diff... 200k miles and she runs smooth as hell now. I dont even feel the rumble when cold anymore and when sitting at a light hard to tell its even running lol def worth$$.
