5100 help
Wrigley17
I had a local shop install bilsteins on all four corners. I had the circlip set at the 1.4" and told them that's where I wanted it. Everything turned out great, I only gained 1" of lift after it settled. It looks to my like it was set on .7", I can only see one ring below which I know is stock, and I can see one ring obove. By the picture can you tell which setting it's on?
freefallin
Tough to tell, but it seems to be on the 3rd notch (1.4). Here are mine at 2.8 for reference.
W
Wrigley17
Thanks man. Do you have any pictures of a more underneath angle? I've seen some pictures on the forum but not at 1.4". I just need to know if the very last ring you can see is one below, or two below what they are actually set at.
W
Wrigley17
AustinB had some great pictures of his, I can see 4 rings so I'm assuming his is on the 5th at 2.8?
Ferro
This is mine set at 1.4. I would say you're at 1.4
W
Wrigley17
Thanks brother. I actually think I'm at .7" because I can only see one ring on the bottom, where as you can see two. I hopped underneath to make sure I can't see anymore than the one.
FlorianB
