Bilstein 5100 with eibach coils
TD84
South carolina
So was wondering if any one has ran this setup. Was thing of pairing th bils with the eibach 2.75 inch coils.
My setup currently: 2009 dodge ram crew cab. Zone 6 inch lift with the 5 inch rear coils. As it stands the rear is about 2.5 inches taller.
Gail is to maybe get 3 inches more up front( the 2.5 in rake plus maybe .5 to 1 inch more) and maybe put a 1 inch coil spacer in the rear to try to squeeze out a little more lift.
If I do this set up; which ring would the bils need to be set at? 1.4, 2.1? I'm guessing maxed out would probably be a bad idea for the shocks. If even possible with the eibachs.
