545rfe transmission
1dbcoleman
St Louis MO
2008 Ram 1500 mega cab 4x4
5.7 hemi stroked to a 6.4
Maybe it's been discussed to death but I am worn out on the whole 545rfe. My 5.7 hemi is stroked to a 396 but pump gas only, Is there a way to build one that actually holds up. Forth time around. I keep loosing overdrive. I have had this thing tor. Apart 4 times. Transmission shop is at its max. Warranty now. What can be done to ensure reliability.
HemiLonestar
MD
With a 545RFE? Absolutely nothing lol. Search the forum for 'ZF swap' or '8HP70 swap'.
1dbcoleman
1dbcoleman
St Louis MO
We have put in the billet overdrive reverse drum. The best internals. Anything you can do to a valve body, HD torque converter, bigger cooler. And if I am crusing on the interstate and want to stomp it I have to turn off the OD so I can without burning up the clutches.
