6” Rough Country lift rattling noise
Kmils0328
Connecticut
I have a 2014 Ram 1500 with a 6” RC lift installed. There is this rattling noise coming from my front drivers side suspension area that occurs every time I go over a bump in the road. I have not been able to identify it and have taken it to three shops who have not been able to diagnose it. Has anyone had a similar issue with this product or has gone through a similar issue with another? Anything to look for or check would help.
crazykid1994
What struts are in the front? Could be strut going bad or a loose bolt somewhere. Strut top plate failed. If you are able to I would go through and check every bolt and pull the strut out as well to check it
Atcer2018
Virginia
+1 on this. Every rattle I’ve ever had on a strut setup was the top plate or center nut.
morgo1
Sudbury
Check your rear diff look at the upper control arm relocation bracket there's a metal sleeve/spacer that's what was rattling on mine
