rwhjr
so ill describe the current setup and go from there
2017 1500 crew cab with a 6" procomp lift
bilsteins on the .7 setting
fenders are meausring:
43.5" front
44.75" rear
(from the ground to the lip of each fender"
im currently running:
factory big horn wheels
1.5" spacers (making my current effective offset roughly -20?)
35x11.5 nitto ridge grapplers
but when i meaure the riding height of these tires theyre actually under 34" from ground to top of tire
it looks like most 37s are about 36.5" in actual height when installed on the vehicle
so.....im looking at adding about 2.5" of tire height possibly.....and theres plenty of room right now, so its not like these current tires are remotely rubbing anything....i just wanna know about what sizes will fit on a typical setup like mine if i go with 37s?
if i get the following should i still be good with not rubbing? if not what would make some 37s fit cleanly???
20x10
-24 to -25 offset
37x12.5 ridge grapplers
43.5" front
44.75" rear
20x10
-24 to -25 offset
