65rfe 4th gen 6 speed auto xsmn .
R/T_Fire
Pleasant Grove
He's running a new tune from Sean. Sounds like the truck is just learning his driving style with the new tune. Pretty sure it had to shift into neutral before he shut it down because it wouldn't start if it was still in fourth. Sounds to me to be tuner related since he had no issues until he put the tune on yesterday
I have had issues before, but that was when I gernaded the trans and it was rebuild at the dealer about 4-6 months ago. Trans has never felt right since rebuild but is also under a 2 yr unlimited mile repair warranty through the dealer... Just want to make sure its nothing I caused before I go raise hell and demand it to be fixed.
Thanks for the help
12sportmc
NC
Thanks for the help
Oh wow yeah that stinks. I'd do as you are planning and return it stock to see what happens before raising hell at the stealership lol. Good luck man.
R.L.K.
R.L.K.
Bristol , Tn.
Definitely remove the Tunner before going in for a warranty claim.
I wonder if the dealer can tell if a Tunner has been installed in the past ?
I'd bet the warranty would be void if they knew there was a tune installed ( even temporary ) regardless of how dissatisfied you were from the rebuild date
Good luck Sir !
R.L.K.
R.L.K.
Bristol , Tn.
I just did a quick Google search of
" 2011 Ram Transmission problems "
Found many pages of issues with your particular issue being #1 on the list
Some guys just keep driving it , turn off , start back up and drive normal for a while , week , days , even a month Untill it happens again ....
Reported repairs were many . Valve body replacements , defected spring in the valve body , shift & pressure solenoids and transducers .... the list goes on & on .
@R/T_FIRE, Is your xsmn the 65RFE ?
How many total miles and how many mils since the rebuild ?
R/T_Fire
Pleasant Grove
Its a 545rfe. Its got about 8k since rebuild.
This is the first time its done this. When i blew out the overdrive cluster is didnt do this. We will see, as for the dealer i will put it back to stock drive for a bit log some data and go from there. Oh and there was no CEL light. Just the stuck in 4th gear issue
Sent from my SM-G920V using Tapatalk
Hemi395
Cape Cod MA
The only "trace" of a tuner that's left behind is the number of times the PCM has been flashed. So theoretically if a bunch of tunes have been flashed they will see the PCM has been flashed a number of times when it should've been 0. Still only circumstancial tho...
R/T_Fire
Pleasant Grove
I dont worry about it too much with this dealer, they are pretty mod friendly and i have had it in there with the diablo hooked up and no issues.
DILLIGAF
Canada
Why would your Diablo be hooked up ? Once the truck is programmed you throw it in a drawer and forget about it... lol...
R/T_Fire
Pleasant Grove
I have the trinity 1000. Extra gauges.
Took the truck back to them to fix a trans pan leak and didnt have time to reset to stock. They didnt care.
12sportmc
NC
Must be nice. Lol. My dealer is very anti mod
Ronan
I had a tranny completely rebuilt all the while having full bolt-ons.
R.L.K.
R.L.K.
Bristol , Tn.
Post some pics when you get yours. I'm curious what your serial number is as mine and DILAGAF were 1 off.
You going to use RL C+?
R.L.K.
R.L.K.
Bristol , Tn.
I probably won't be installing for a few.months , ha ha may not be able to wait !
R/T_Fire
Pleasant Grove
Is a 66rfe stronger than a 545rfe and is it possible to use the guts of a 66rfe in a 545 to keep it from blowing up all the time when adding hp...
Hemi395
Cape Cod MA
@R.L.K., can you take a pic of the inside of the pan? I can't remember if the drain hole in the MH pan sticks up at all...
R.L.K.
R.L.K.
Bristol , Tn.
I'll try to remember to do this in the morning Sir !
R.L.K.
R.L.K.
Bristol , Tn.
Damnit , I 4 got to take a pic of the inside .....
iralee
