65RFE to 8HP70 Swap , Lifted Truck Edition!
DILLIGAF
DILLIGAF
Canada
Got to go around the block.
Doing the fill process, I burned the **** out of my finger putting the bolt back on the trans, the header cross pipe is perfectly in the way.
Not shifting how I want, but seems to go thru the gears with no issues. I just pulled the TCM file and sending it off to Flyin' Ryan today.
No Codes , but noticed a small drip so back on the lift to check the fittings.
Tried to do a Trans relearn with Alfa ODB, Wont work, emailed SGA about it and he confirmed this.
Filling it on a lift usually doesn't get the proper fluid level in the transmission unless you've somehow managed to level the pan rail.
I'm assuming you've seen these instructions,but here they are again,and leveling the 8 speed is mucho important.
DILLIGAF
DILLIGAF
Canada
All buttoned up. Just waiting on FRP and Front Drive shaft!
@Wild one I know I suffer from extreme retardation but come on man ! LoL.. I wouldn't of burned my finger with the truck on the lift, instead I was on the ground like a ******* peasant...lol..
smoothee
St. John's, NL
Wicked! How does it like those 4.56's? Lol
JBA crossover isn't too close is it?
Just wondering if there would be much of a difference between them and my ARH as far as clearance goes
I'm ashamed to say my 8 speed is still sitting in the garage, just trying to kill the ol 5 speed
DILLIGAF
DILLIGAF
Canada
I dont like the shift points right now at all, or how it performs. SGA said everything looked good in the LOG files.
So im thinking its a tuning issue, Been emailing back and forth with FRP and should have a new tune tomorrow ! :crazy:
smoothee
St. John's, NL
I'm sure he'll get it dialed in. I was wondering if a Quicklearn could be done after the swap with Alfa, good to know now that it can't.
olyelr
Kewadin MI
DILLIGAF
DILLIGAF
Canada
Decided to draw up a simple Transmission skid plate. Pretty sweets it was able to fit on a half sheet, specially at the price 3/16th is at these days. ... :crazy:
You better wrap the hell out of your crossover then,as you're going to be trapping alot of heat under the pan
DILLIGAF
DILLIGAF
Canada
Always sumthin!!! Screw it, have another gummy then lmao
Just got my order yesterday ! I did Chocolates and Brownies this month instead of Gummies, Looking forward to trying those 2 Cigars around the campfire this weekends :p
